Tích 2 số Mã: /** * @(#)tich.java * * * @author * @version 1.00 2011/1/18 */ import java.util.Scanner; public class tich { /** * Creates a new instance of <code>tich</code>. */ public tich() { } /** * @param args the command line arguments */ public static void main(String[] args) { // TODO code application logic here Scanner s = new Scanner(System.in); int a = s.nextInt(); int b = s.nextInt(); int c = a*b; System.out.print("tong la:"+c); } } Tính Tổng Mã: import java.util.Scanner; public class Tinhtong { /** * Creates a new instance of <code>songuyen</code>. */ public Tinhtong() { } /** * @param args the command line arguments */ public static void main(String[] args) { // TODO code application logic here Scanner s = new Scanner(System.in); int a = s.nextInt(); int b = s.nextInt(); int c = a+b; System.out.print("tong la:"+c); } } Số nguyên tố Mã: /** * @(#)songuyento.java * * * @author * @version 1.00 2011/1/18 */ import java.util.*; public class songuyento { /** * Creates a new instance of <code>songuyento</code>. */ public songuyento() { } /** * @param args the command line arguments */ public static void main(String[] args) { // TODO code application logic here int i,s=0; Scanner a=new Scanner(System.in); int n=a.nextInt(); if (n==0||n==1) { System.out.print(n+" ko phai la so nguyen to");return;} if(n==2) {System.out.print(n+" la so nguyen to");return;} for(i=2;i<=n/2;i++) if(n % i == 0) {s=1; break;} if(s==0) System.out.print(n+" la so nguyen to"); else System.out.print(n+" ko phai la so nguyen to"); } } Dãy fibonaxi Mã: /** * @(#)fibonaci.java * * * @author * @version 1.00 2011/1/18 */ import java.util.*; public class fibonaci { /** * Day fibonaci */ public static int nhap() { Scanner s= new Scanner(System.in); boolean check=false; int n=0; return(n); } static boolean kt_fibo(int n) { boolean kt=true; if(n<=1) return false; int f1=1,f2=1,fi=2; while(!false) { int t=f1; f1=f2; f2=t+f2; kt=false; break; } return kt; } public static void main(String[] args) { Scanner s=new Scanner(System.in); System.out.println("Nhap bao nhieu phan tu cua mang "); //Nhap so luong phan tu int k = s.nextInt(); int [] dayso; //khai bao mang dayso = new int [100]; System.out.println("Nhap mang "); for(int i=0;i<=k-1;i++) { System.out.println("Nhap so phan tu thu " + i); dayso [i]= nhap(); } //Xuat mang System.out.println("Cac phan tu la so fibonaci cua mang "); for(int i =0;i<=k-1;i++){ if(kt_fibo(dayso[i])) System.out.println("So " + dayso [i] + " la so fibonaci"); else System.out.println("So " + k + " khong phai la so fibo"); } } } Chu vi, diện tích Mã: import java.util.scanner; class BAI1 { public static void main(String[] args) { Scanner s = new Scanner(System.in); float pi=3.14; float a = r.nextInt(); system.out.println("nhap vao ban kinh r :"); double cv=2*pi*r; double dt=pi*r*r; system.out.println("chu vi la :"+cv); system.out.println("dien tich la :" +dt); } } Tham khảo thêm tại đây [NOTE]http://www.mediafire.com/?k77i6fsfjged998[/NOTE]
