Portable Screenpresso PRO 1.3.3 - Cracked
Thảo luận trong 'Ứng dụng nhỏ' bắt đầu bởi vncrack, 18 Tháng năm 2012.
    vncrack
    Portable Screenpresso PRO 1.3.3 | 8 mb
    Screenpresso captures your screen (screenshots and HD videos) for your training documents, collaborative design work, IT bug reports, and more...
    Screenpresso overrides the Print Screen key and makes it easy to take the best screen captures in a few seconds. It is a light-weight Windows software giving a wonderful look to your screenshots!
    Features:
    Capture windows and region
    Capture part of the screen or a specific window with the same shortcut. Simple.
    Portable application
    No need to install the application, you can run it directly after download.
    Screenshot history
    Don’t bother to save screenshots on your drive, Screenpresso does it for you. Practical.
    Attach screenshots to emails
    Drag and drop screenshots from the history directly to your favorite email editor. Webmails like GMail are also taken into account! Swift.
    Built-in image editor
    Crop, spotlight an area or comment parts of a captured image. Efficient.
    Capture scrolling part
    Can’t fit it on the screen ? Make a unique image thanks to the stitching mechanism. Smart.
    Add effects
    Look like a pro. Add drop shadow, rounded corners, reflection and more. Sleek.
    Resize bunch of images
    Need to export images or create thumbnails at a specific size, one click.
    Share screenshots
    Easily share your screenshots via Twitter, Facebook, G-Mail, Evernote, Flickr or FTP.
    Great support
    Simply send an e-mail to support team. It will always quickly respond.
    Download from Vip-file
    Download from Letitbit
