System Information Viewer 4.30 Portable
Thảo luận trong 'Ứng dụng nhỏ' bắt đầu bởi vncrack, 2 Tháng bảy 2012.
    vncrack
    System Information Viewer 4.30 Portable | 4.2 MB
    System Information Viewer is a general Windows utility for displaying lots of useful Windows, Network and hardware info - CPU info, PCI info, PCMCIA info, USB info, Machine Info, Hardware Sensors, Networked computers, Operating System Information and more. I use Craig Hart's pcidevs.txt file for my PCI device display with my usbdevs.txt being used for the USB devices, mondevs.txt for monitor descriptions and pcmdevs.txt for PCMCIA device descriptions.
    Changelog:
    · Windows 8 Release Preview V6.02 Build 8400 support validated and driver ACPI operations enabled
    · Added the [Embedded Controller] page and EC sensor reporting for ASUS P8Z77 motherboards
    · Added Enable of the X7, P7, P6 and P5 Series Chipset Thermal Controller
    · Update [GPU Apps] to allow for no nVidia GPU when NVAPI is present
    · Update to use --get_state for BOINC V7.00.26 and later as the --get_simple_gui_info output has changed
    · Added -INIT=NOAPM to tell SIV to try and Disable APM on all the disk drives and then exit
    Download Links:
