Tài liệu Một số ebook C# 2010
Thảo luận trong 'Lập trình máy tính' bắt đầu bởi ebookgroup, 13 Tháng mười hai 2011.
    ebookgroup
    Beginning Visual C# 2010
    Update to Wrox’s leading C# book for beginners
    Get ready for the next release of Microsoft’s C# programming language with this essential Wrox beginner’s guide. Beginning Microsoft Visual C# 2010 starts with the basics and brings you thoroughly up to speed. You’ll first cover the fundamentals such as variables, flow control, and object-oriented programming and gradually build your skills for Web and Windows programming, Windows forms, and data access.
    Step-by-step directions walk you through processes and invite you to "Try it Out," at every stage. By the end, you’ll be able to write useful programming code following the steps you’ve learned in this thorough, practical book.
    • The C# 4 programming language version will be synonymous with writing code with in C# 2010 in Visual Studio 2010, and you can use it to write Windows applications, Web apps with ASP.NET, and Windows Mobile and Embedded CE apps
    • Provides step-by-step instructions for mastering topics such as variables, flow controls, and object-oriented programming before moving to Web and Windows programming and data access
    • Addresses expressions, functions, debugging, error handling, classes, collections, comparisons, conversions, and more
    If you’ve always wanted to master Visual C# programming, this book is the perfect one-stop resource.
    Download:
    Password: ebookgroup.org
    C# 2010 for Programmers, 4th Edition
    The professional programmer’s Deitel® guide to C# 2010 and the powerful Microsoft® .NET 4 Framework
    Written for programmers with a background in C++, Java or other high-level, object-oriented languages, this book applies the Deitel signature live-code approach to teaching programming and explores Microsoft’s C# 2010 language and .NET 4 in depth. The book is updated for Visual Studio® 2010 and C# 4, and presents C# concepts in the context of fully tested programs, complete with syntax shading, detailed line-by-line code descriptions and program outputs. The book features 200+ C# applications with 17,000+ lines of proven C# code, as well as hundreds of programming tips that will help you build robust applications.
    Start with a concise introduction to C# fundamentals using an early classes and objects approach, then rapidly move on to more advanced topics, including multithreading, .NET 4, LINQ, WPF, ASP.NET 4, WCF web services and Silverlight®. Along the way you’ll enjoy the Deitels’ classic treatment of object-oriented programming and the OOD/UML® ATM case study, including a complete C# implementation. When you’re finished, you’ll be ready to build next-generation Windows applications, web applications and web services.
    Download:
    ebookgroup
    CLR via C#, 3rd Edition
    Dig deep and master the intricacies of the common language runtime (CLR) and the .NET Framework 4.0. Written by a highly regarded programming expert and consultant to the Microsoft® .NET team, this guide is ideal for developers building any kind of application-including Microsoft® ASP.NET, Windows® Forms, Microsoft® SQL Server®, Web services, and console applications. You’ll get hands-on instruction and extensive C# code samples to help you tackle the tough topics and develop high-performance applications.
    Download:
    ebookgroup
    C# in Depth, Second Edition
    C# has changed significantly since it was first introduced. With the many upgraded features, C# is more expressive than ever. However, an in depth understanding is required to get the most out of the language.
    C# in Depth, Second Edition is a thoroughly revised, up-to-date book that covers the new features of C# 4 as well as Code Contracts. In it, you’ll see the subtleties of C# programming in action, learning how to work with high-value features that you’ll be glad to have in your toolkit. The book helps readers avoid hidden pitfalls of C# programming by understanding “behind the scenes” issues.
    Download
    Link Mediafire
    Link Hotfile
