Winamp 5.63.3235 Pro Portable | 14.18 Mb Winamp - one of the most popular media player that allows you to work with files in the formats MP3, OGG, AAC, WAV, MOD, XM, S3M, IT, MIDI, and others, including video formats AVI, ASF, MPEG, NSV. Can listen to streaming recordings, interact with online shopping and online services that synchronize music with portable digital music players and much more. In addition, incorporates a special library to organize your music collection. Differences between the three versions of the program are the presence of modules to support different formats, as well as additional features. Version of Winamp Pro is the only commercial package that features the function of copying an audio CD into various formats and transcoding files. The program interface is translated into several languages, including Russian language. Main characteristics of Winamp: * Simple, easy to use but rich in features interface. Easy access to the media library, playlist, integrated graphics and visualization, equalizer, winamp skins. Ability to change the theme colors of the windows. * Playlist. Just drag and drop media files to the playlist from Windows Explorer or the Media Library Winamp. Sort list by title, file name, the author of songs ... Rapid opening and saving of playlists by pressing the manager playlists. * Media Library. Store and search your media files in one place. Ability to write files from CD to computer and from your computer to a CD. Editing tags of music files (artist, song, album, etc.). Access to Internet radio and TV. Additional information (discography, biography, album covers) on your favorite artists and bands in the player Winamp. * Video playback. A large number of supported formats (NSV, WMV, MPG and many others). Easy change of screen sizes and formats. Many (about 100) of beautiful visual images. Ability to view a random screen saver mode. Easy transition to full screen mode. Additional visual images for the player Winamp. * Equalizer. The balance control. Smooth transition from one song to another. Many standard EQ settings. Ability to create and maintain your own equalizer settings. New features: * Internal support for playback of video encoded in H.264 (Pro version only) * Purchase tickets and music, as well as search lyrics straight out of the windows media player * Compatible with Windows 7 * Winamp OrglerTM - the ability to track, make charts and conduct public history plays * Find and control the plug directly into your media player * 16 language packs, including Turkish, Romanian and Brazilian Portuguese * The version of "Pro"! Rips CDs to MP3 format * The version of "Pro"! Rips CDs into formats aacPlus, AAC, WMA * The version of "Pro"! Rips CDs in the format HE-AAC * The version of "Pro"! Burning CDs Winamp 5.63 - New: Winamp now available in Hungarian and Indonesian languages - New: [enc_vorbis] encoder Ogg Vorbis (based on aoTuV) - Improved: Support for shortcut keys SHIFT + F10 to bring up the context menu in the Winamp library - Improved: [enc_fhgaac] The mode number 6 for the variable rate (VBR), a small improvement of quality - Improved: [in_mod] The procedure for allocating memory was better, easier and thread - Improved: [ml_history] Now, data on the number of reproductions preserved during an upgrade, not just when you exit Winamp - Improved: [ml_local] Buffers searches increased from 512 to 2048 or 1024 bytes - Improved: [gen_hotkeys] Now you can assign shortcut keys for manual operation and for work with visual images - Fixed: Album Covers, embedded in the files, sometimes not displayed - Fixed: [aacdec] Memory leak when re-sync with the flow of AAC - Fixed: [bmp] Check out abroad array in TSCC decoder - Fixed: [bmp] Problems that caused a buffer overflow on the heap (thank Secunia) - Fixed: [in_avi] problems with division by zero, and a pointer to NULL (thank FuzzMyApp) - Fixed: [in_mod] Problems that caused damage to the heap (memory) when playing a file format IT (thank Jeremy Brown of the MSVR) - Fixed: [ml_local] Error in cache MLDBAPI :: SetField, caused it to crash - Fixed: [pmp_android / usb] Genre and year were recorded in the disc number in the metadata - Fixed: [vis_milk2] Visual images did not respond to music in the localized versions of Winamp (MilkDrop 2.25) - Other: Many different changes, improvements, fixes and optimizations - Updated: [aacdec] Fraunhofer AAC decoder to version 1,762,208 - Updated: [in_vorbis] library to version 1.3.0 libogg and libvorbis to version 1.3.3 - Updated: [lame_enc] LAME encoder to version 3.99.5 - Updated: [png] libpng library to version 1.5.10 - Updated: [vp8] libvpx library to version 1.0.0 - Updated: [zlib.dll] zlib library to version 1.2.7 - Location: [ru-RU] Returned "Close" button in the Options window Winamp Changes in Winamp 5.63 (June 28, 2012) * New: Winamp is now available in Hungarian and Indonesian languages * New: [enc_vorbis] encoder Ogg Vorbis (based on aoTuV) * Improved: Support for shortcut keys SHIFT + F10 to bring up the context menu in the Winamp library * Improved: [enc_fhgaac] The mode number 6 for the variable rate (VBR); little to improve the quality * Improved: [in_mod] The procedure for allocating memory was better, easier and thread * Improved: [ml_history] Now, data on the number of reproductions preserved during an upgrade, not just when you exit Winamp * Improved: [ml_local] Buffers searches increased from 512 to 2048 or 1024 bytes * Improved: [gen_hotkeys] Now you can assign shortcut keys for manual operation and for work with visual images * Fixed: album cover, embedded in the files, sometimes not displayed * Fixed: [aacdec] Memory leak when re-sync with the flow of AAC * Fixed: [bmp] Check out abroad array in TSCC decoder * Fixed: [bmp] The problems that caused a buffer overflow on the heap (thank Secunia) * Fixed: [in_avi] problems with division by zero, and a pointer to NULL (thank FuzzMyApp) * Fixed: [in_mod] The problems that have caused damage to the heap (memory) when playing a file format IT (thank Jeremy Brown of the MSVR) * Fixed: [ml_local] Error in cache MLDBAPI :: SetField, caused it to crash * Fixed: [pmp_android / usb] Genre and year were recorded in the disc number in the metadata * Fixed: [vis_milk2] Visual images did not respond to music in the localized versions of Winamp (MilkDrop 2.25) * Other: A huge number of different changes, improvements, fixes and optimizations * Updated: [aacdec] Fraunhofer AAC decoder to version 1,762,208 * Updated: [in_vorbis] library to version 1.3.0 libogg and libvorbis to version 1.3.3 * Updated: [lame_enc] LAME encoder to version 3.99.5 * Updated: [png] libpng library to version 1.5.10 * Updated: [vp8] libvpx library to version 1.1.0 * Updated: [xml] expat library to version 2.1.0 * Updated: [zlib.dll] zlib library to version 1.2.7 * Location: [ru-RU] Returned "Close" button in the Options window Winamp DOwnload High Speed
