[Up date] Bài tập SQL(Quản Lý Bán Hàng) trên lớp từ câu 1 tới câu 22!
Thảo luận trong 'Khoa Khoa Học Máy Tính' bắt đầu bởi Ctrl+F9, 25 Tháng mười 2011.
    Ctrl+F9
    • Đăng kí mới , gửi mail xác nhận không được kìa :v ..............
    PHP:
    create database qlbh_nguyenquocphu_cclt04c
    use qlbh_nguyenquocphu_cclt04c
    create table khachhang
    makhachhang nvarchar(10)
    constraint pk_khachhang_makhachhang primary key,
    tencongty nvarchar(50not null,
    tengiaodich nvarchar(50not null,
    diachi nvarchar(50null,
    email nvarchar(40null,
    dienthoai nvarchar(11null,
    fax nvarchar(11null
    create table nhanvien
    manhanvien nvarchar(10
    constraint pk_nhanvien_manhanvien primary key,
    ho nvarchar(10not null,
    ten nvarchar(15not null,
    ngaysinh datetime null,
    ngaylamviec datetime null,
    diachi nvarchar(100),
    dienthoai nvarchar(11),
    luongcoban nvarchar(8not null,
    phucap nvarchar(8not null
    create table nhacungcap
    macongty nvarchar(10
    constraint pk_nhacungcap_macongty primary key,
    diachi nvarchar(50not null,
    fax nvarchar(11null,
    create table loaihang
    maloaihang nvarchar(10
    constraint pk_loaihang_maloaihang primary key,
    tenloaihang nvarchar(30)
    create table dondathang
    sohoadon nvarchar(10not null
                    constraint pk_dondathang_sohoadon primary key
    makhachhang nvarchar(10not null,
    constraint fk_dondathang_makhachhang
                    foreign key
    (makhachhang)
    references khachhang(makhachhang)
    on delete cascade
                    on update cascade
    manhanvien nvarchar(10not null,
    constraint fk_dondathang_manhanvien
                    foreign key
    (manhanvien)
    references nhanvien(manhanvien)
    on delete cascade
                    on update cascade
    ngaydathang datetime not null,
    ngaygiaohang datetime not null,
    ngaychuyenhang datetime not null,
    noigiaohang nvarchar(50not null
    create table mahang
    mahang nvarchar(10)
    constraint pk_mahang_mahang primary key,
    tenhang nvarchar(30not null,
    macongty nvarchar(10not null,
    constraint fk_mahang_macongty
                foreign key
    (macongty)
    references    nhacungcap(macongty)
    on delete cascade
                on update cascade
    maloaihang nvarchar(10not null,
    constraint fk_mahang_maloaihang
                foreign key
    (maloaihang)
    references loaihang(maloaihang)
    on delete cascade
                on update cascade
    soluong nvarchar(5not null,
    donvitinh nvarchar(5not null,
    giahang nvarchar(5not null
    create table chitietdathang
    sohoadon nvarchar(10not null,
    constraint fk_chitietdathang_sohoadon
                foreign key
    (sohoadon)
    references dondathang(sohoadon)
    on delete cascade
                on update cascade
    mahang nvarchar(10not null,
    constraint fk_chitietdathang_mahang
                foreign key
    (mahang)
    references mahang(mahang)
    on update cascade
                on delete cascade
    giaban nvarchar(5not null,
    mucgiamgia nvarchar(5not null
    use
    select
    from nhacungcap
    insert into nhacungcap
        values
    ('CT01','Khai Huy','TMDVMT','56 Ham Nghi','05113245632','124563','khaihuy@gmail.com')
        values
    ('CT02','Viet Tien','VT','61 Le Duan',05113478342,895674,'viettien@gmail.com')
        values
    ('CT03','Ben Thanh','BBT','58 Nguyen Van Linh',051134789521,475102,'benthanh@gmail.com')
        values
    ('CT04','Hong Ha','HH','110 Phan Thanh',05113869574,145268,'hongha@gmail.com')
        values
    ('CT05','Kinh Do','KD','87 Phan Chau Trinh',05113578954,587695,'kinhdo@gmail.com')
    select *from loaihang
    insert into loaihang
        values
    ('101','Ao Quan')
        values
    (102,'Man Hinh')
        values
    (103,'Chip')
        values
    (104,'Banh Keo')
        values
    (105,'Bia')
    select from mahang
    insert into mahang
        values
    ('MH01','Ao','CT01','101',1000,'$',30)
    insert into mahang
        values
    ('MH02','Man Hinh','CT02',102,2000,'$',20)
    insert into mahang
        values
    ('MH03','Chip','CT03',103,3000,'$',150)
    insert into mahang
        values
    ('MH04','Mouse','CT04',104,4000,'$',50)
    insert into mahang
        values
    ('MH05','My Pham','CT05',105,7000,'$',120)
    select from nhanvien
    insert into nhanvien
        values
    ('NV01','Nguyen Thi','Hong Hue','01/01/88','7/10/08','71 Le Duan',0972939005,5000,400)
        values
    ('NV02','Luong','Huy','07/11/87','8/8/08','80 Nguyen Van Linh',0905220243,6000,500)
        values
    ('NV03','Nguyen Lan','Phuong','2/08/88','07/05/08','18 Phan Chau Trinh',0986979030,3000,500)
        values
    ('NV04','Tran Thanh','Hien','11/12/88','8/9/08','110 Phan Thanh',05113562452,3000,400)
        values
    ('NV05','Nguyen Anh','Ngoc','07/07/88','08/06/08','88 Le Duan',0905855222,4000,900)
    select *from khachhang
    insert into khachhang
        values
    ('KH01','Toan Gia','TMDV','81 Ham Nghi','toangia@gmail.com','05113548756',425876)
        values
    ('KH02','Khai Huy','MVT','21 Le Duan','khaihuy@gmail.com',0987541299,542854)
        values
    ('KH03','Kinh Do','BKD','12 Nguyen Van Linh','kinhdo@gmail.com',05113976293,5876942)
        values
    ('KH04','Nam A','DTDD','20 Hoang Dieu','nama@gmail.com',0988497293,789523)
        values
    ('KH05','Toan Thang','TTT','110 Phan Thanh','toanthang@gmail.com',0905855222,145278)
    select from dondathang
    insert into dondathang
        values
    ('001','KH02','NV01','1/1/07','11/11/08','12/1/08','52 Hoang Dieu')
        values
    ('002','KH01','NV02','1/1/08','11/11/08','12/01/08','110 Phan Thanh')
        values
    ('003','KH03','NV05','1/1/08','11/11/08','12/01/08','15 Le Duan')
        values
    ('004','KH03','NV02','1/1/08','11/11/08','12/01/08','21 Nguyen Van Linh')
        values
    ('005','KH04','NV04','1/1/08','11/11/08','12/1/08','52 Phan Chau Trinh')
    select from chitietdathang
    insert into chitietdathang
        values
    ('001','MH02','50',200,50)
        values
    ('002','MH02',45,800,9)
        values
    ('003','MH03',50,10,2)
        values
    ('004','MH04','110','1000',12)
        values
    ('005','MH05',12,500,2)
    Cau 1:Cho biết danh sách các đối tác cung cấp hàng cho công ty.
    select tencongty
        from nhacungcap
    Cau 2
    :Mã hàngtên hàng và số lượng của các mặt hàng hiện có trong công ty.
    select mahang,tenhang,soluong
        from mahang
    Cau 3
    :Họ tên và địa chỉ và năm bắt đầu làm việc của các nhân viên trong công ty.
    select ho,ten,diachi,year(ngaylamviec) as namlamviec
        from nhanvien
    Cau 4
    :Địa chỉ và điện thoại của nhà cung cấp có tên giao dịch VINAMILK  là gì?
    select diachi,dienthoai
        from nhacungcap
        where tengiaodich
    'HH'
    Cau 5Cho biết mã và tên của các mặt hàng có giá lớn hơn 100000 và số lượng hiện có ít hơn 50.
        select mahang
    ,tenhang
        from mahang
        where giahang
    >50 and soluong<5000
    Cau 6
    Cho biết mỗi mặt hàng trong công ty do ai cung cấp.
    select mahang,tenhangnhacungcap.macongty,tencongty,tengiaodich
        from mahang
    ,nhacungcap
        where mahang
    .macongty=nhacungcap.macongty
    Cau 7
    :    Công ty Việt Tiến đã cung cấp những mặt hàng nào
        select mahang
    ,tencongty,tenhang
        from mahang
    ,nhacungcap
        where mahang
    and tencongty like '%Viet Tien'
    Cau 8:Loại hàng thực phẩm do những công ty nào cung cấp và địa chỉ của các công ty đó là gì?
    select tenhang,nhacungcap.macongty,tencongty,diachi
        from mahang
    ,nhacungcap
        where mahang
    and tenhang like '%My Pham'
    Cau 9:Những khách hàng nào (tên giao dịchđã đặt mua mặt hàng Sữa hộp XYZ của công ty?
    select tengiaodich
        from khachhang
    ,dondathang,chitietdathang,mahang
        where
            khachhang
    .makhachhang=dondathang.makhachhang and
    dondathang.sohoadon=chitietdathang.sohoadon and
    chitietdathang.mahang=mahang.mahang and
    tenhang='Chip'
    Cau 10Đơn đặt hàng số 1 do ai đặt và do nhân viên nào lậpthời gian và địa điểm giao hàng là ở đâu?
    select nhanvien.manhanvien,ho,ten,ngaygiaohang,noigiaohang
        from khachhang
    ,nhanvien,dondathang
        where khachhang
    dondathang.manhanvien=nhanvien.manhanvien and
    sohoadon='001'
    Cau 11:Hãy cho biết số tiền lương mà công ty phải trả cho mỗi nhân viên là bao nhiêu (lương lương cơ bản phụ cấp).
    SELECT manhanvien,ho,ten,luong luongcoban phucap
        from nhanvien
    Cau 12
    :Trong đơn đặt hàng số 3 đặt mua những mặt hàng nào và số tiền mà khách  hàng phải trả cho mỗi mặt hàng là bao nhiêu (số tiền phải trả được tính theo công thức
    SOLUONG×GIABAN – SOLUONG×GIABAN×MUCGIAMGIA
    /100)
    select sohoadon,mahang,tenmathang,sotien=soluong*giaban-soluong*giaban*mucgiangia/100
        from mahang
    ,nhanvien,chitietdathang
        where
    Cau 14
        2.14    Trong công ty có những nhân viên nào có cùng ngày sinh
    select manhanvien,ho,ten,day(ngaysinh) as ngaysinh
        from nhanvien
        where ngaysinh not in
    (select ngaysinh
                        from nhanvien
    2.15    Những đơn đặt hàng nào yêu cầu giao hàng ngay tại công ty đặt hàng và những đơn đó là của công ty nào?
    select sohoadon,noigiaohang,tencongty
        from dondathang
    ,khachhang
        where khachhang
    .diachi=dondathang.noigiaohang
    2.16    Cho biết tên công ty
    ,  tên giao dịchđịa chỉ và điện thoại của các khách hàng và các nhà cung cấp hàng cho công ty
        select tencongty
    ,tengiaodich,diachi,dienthoai
        from khachhang
        union all
        select tencongty
        from nhacungcap
    2.17    Những mặt hàng nào chưa từng được khách hàng đặt mua
        from mahang
        where mahang  not in
    (select mahang
                        from chitietdathang
    2.18    Những nhân viên nào của công ty chưa từng lập bất kỳ một hoá đơn đặt hàng nào?
        from nhanvien
        where manhanvien  in
    (select manhanvien
                                from nhanvien
    2.19    Những nhân viên nào của công ty có lương cơ bản cao nhất?
    select manhanvien,ho,ten,luongcoban
        from nhanvien
        where luongcoban
    =(select max(luongcoban)
    from nhanvien)
    Jayhoo
    Đang cần.Thank you!!!
    Ruakio2
    1-22 mà mới 1 đến 19
    Cau 12:Trong đơn đặt hàng số 3 đặt mua những mặt hàng nào và số tiền mà khách hàng phải trả cho mỗi mặt hàng là bao nhiêu (số tiền phải trả được tính theo công thức
    /100)
    from mahang
    where
    câu 12 chưa viết xong
    câu 13 chưa viết
    bảng chitietdathang và bảng mahang định nghĩa sai kiểu
    ạc
    sâx
    duynghiala
    a ơi cái đề tài
    e đang rất cần nhưng a up lên còn thiếu câu 13,12 chưa hoàn thành còn 1 số câu nữa a gửi cho e đc k ạ
    duynghiala@gmail.com
    cảm ơn a nhá
