Wise Registry Cleaner 7.33 Build 471 Portable | 5 Mb Wise Registry Cleaner - utility to clean registry Windows. Allows you to safely remove from the register of the wrong or unnecessary information. Wise Registry Cleaner Free at startup proposes to make a backup of the registry, so that you could restore it. In addition, after scanning the registry Wise Registry Cleaner shares found a few bugs in the sound (which can be easily removed), and such, the appropriateness of removal which is at issue, as this may lead to an unstable operating system. Finally, there is an automatic mode, in which the program will be run independently, fix registry errors and shut down. Key features: • The safest Registry cleaning tools available in the market today • Fast, thorough and safe work • Scan Windows registry and find incorrect or obsolete information • The output of each problem separately, together with their description • Automatic cleaning of the registry • Undo the acts committed in the system a few mouse clicks • Create a backup system registry and restore • Increase your system performance Changes: • Improved cleaning security • Improved French, Spanish and Wsedish language packs • Fixed some bugs DOwnload High Speed
