CyberLink Power2Go 8.0.0.1429 Full Serial key
Thảo luận trong 'Phần mềm' bắt đầu bởi vncrack, 30 Tháng sáu 2012.
    vncrack
    CyberLink Power2Go 8.0.0.1429 Full Crack / Serial key
    CyberLink Power2Go is a software designed to solve all the problems related to CD / DVD/ BD like a burn, copy, recover, backup, RIP, create slide shows and various other matters relating to the CD / DVD/ BD. You can imagine, that you have software that has the ability to overcome all the problems associated with CD / DVD/ BD in just one software.
    CyberLink Power2Go allows you to record all kinds of data and you also can protect your data on CD / DVD/ BD by using a password, hide file names and folder structure and everything else. With Power2Go can also extract audio tracks from video files and create audio CDs, rip and burn video DVDs with Dolby Digital sound support.
    Features :
    Ability to create mixed media discs (audio / video / photos on the same disk)
    Copy songs from your CDs to MP3, WMA or WAV files
    DVD Authoring for creating a menu to record on DVD
    Full range of instruments for recording various file formats and disc types
    Inserting DVD chapters
    Instant Search (search using file names or tags in the case of music files)
    Slideshow editor for converting photos into slideshows
    Support for Blu-ray Disc allows you to save huge amounts of data, such as backing up movie and photo files
    Supports automatic splitting of files across multiple disks, if the file size exceeds the available space.
    Supports both NTSC and PAL
    The normalization between tracks
    VCD and DVD burning
    Video Trimming and many more.
    Requirements :
    Windows XP/ Vista/ 7 (32 and 64 bits)
    800 MHz of Processor
    256 GB of RAM
    1024 x 768 screen resolution
    Download Now
