Code kí pháp nghịch đảo Ba Lan viết bằng Pascal. học qua cấu trúc dữ liệu chắc bạn cũng biết bài này. tham khảo: PHP: program ConvertInfixToRPN; const Opt = ['(', ')', '+', '-', '*', '/']; var T, Infix, Stack: String; p: Integer; procedure StackInit; begin Stack := ''; end; procedure Push(V: Char); begin Stack := Stack + V; end; function Pop: Char; begin Pop := Stack[Length(Stack)]; Dec(Stack[0]); end; function Get: Char; begin Get := Stack[Length(Stack)]; end; procedure Refine(var S: String); var i: Integer; begin S := S + ' '; for i := Length(S) - 1 downto 1 do if (S[i] in Opt) or (S[i + 1] in Opt) then Insert(' ', S, i + 1); for i := Length(S) - 1 downto 1 do if (S[i] = ' ') and (S[i + 1] = ' ') then Delete(S, i + 1, 1); end; function Priority(Ch: Char): Integer; begin case ch of '*', '/': Priority := 2; '+', '-': Priority := 1; '(': Priority := 0; end; end; procedure Process(T: String); var c, x: Char; begin c := T[1]; if not (c in Opt) then Write(T, ' ') else case c of '(': Push(c); ')': repeat x := Pop; if x <> '(' then Write(x, ' '); until x = '('; '+', '-', '*', '/': begin while (Stack <> '') and (Priority(c) <= Priority(Get)) do Write(Pop, ' '); Push(c); end; end; end; begin Write('Infix = '); Readln(Infix); Refine(Infix); Writeln('Refined: ', Infix); Write('RPN : '); T := ''; for p := 1 to Length(Infix) do if Infix[p] <> ' ' then T := T + Infix[p] else begin Process(T); T := ''; end; while Stack <> '' do Write(Pop, ' '); Writeln; end.
