Portable Business Card Designer Plus v10.1.0.0
Thảo luận trong 'Ứng dụng đồ họa' bắt đầu bởi inuyzika, 12 Tháng một 2011.
    inuyzika
    Portable Business Card Designer Plus v10.1.0.0 | 13.66 MB
    Simply the best business card software available! Our business card software takes the complexity and confusion out of designing and printing your own custom business cards. Use our business card software to create custom business cards as you need them. Contains hundreds of professionally designed business card templates, backgrounds, textures and graphics. Includes support for all business card stock, vertical, horizontal, folded and double sided layout. Create great looking, functional business cards that get results in just a few minutes.
    Key Benefits:
    Create a Business Card FAST!: Use the Design Wizard to create a great looking business card from one of hundreds of business card templates in literally seconds. If you prefer you can also create a blank card and design it yourself. View Tutorial
    Thousands of pre-defined backgrounds, textures and clipart images: In addition, all common image formats are supported so you can use your own pictures, logos and clipart to design the perfect custom business card for you. You can even scan pictures from a scanner or a digital camera directly into your design with our business card software.
    Support for ALL Business Card Stock: Design US size, metric size or custom business cards. Cards of any size between 1 to 4 inches can be created.
    Support for all Styles of Business Cards: Standard Wide, Tall, Double Sided, Photo Quality, Folded and CD-R Business Cards. You name it and this business card software can handle it.
    Print it Yourself or Have it Printed Professionally: You can print your business card on your computer's printer and achieve excellent results or you can save your business card as an image and take it to your local print shop to have your custom business card printed professionally.
    Custom Printing Options: With our business card software you can print any number of business cards starting at any position on the sheet on any Windows compatible printer using our business card printing software.
    Rich Text: Mix fonts, styles and colors of text within a single rich text object.
    Graphic Effects: Crop, mirror, flip, rotate, negative, noise, gamma, etc. Even give a graphic a transparent background with our business card software. View Tutorial
    Useful Shape Tools: Draw lines, rectangles, triangles, ellipses, diamonds and more. Use blending to make the background semi-transparent, blending into whatever is behind the shape.
    Text Effects: Our business card software lets you draw spiral, radial, arc and variable size text. Change the font, size, color, style, shadow rotation and blending. You can even display text as a barcode, an auto-increment counter or the current date and/or time.
    Gradient and Texture Fills with Alpha Blending: Use a gradient or select a texture or image to fill text and shape objects to create outstanding custom business cards. Alpha Blending allows you to blend the gradient or texture into whatever is behind it.
    Store Business Card Information for Multiple Employees: The built-in Personal Database to store information for multiple cards so printing cards for employees is a breeze.
    Affordable: Design as many business cards and print as many copies as you want for a $29.95 US one time license charge. You can't beat our business card software!
    DOWNLOAD
    http://www.filesonic.com/file/56315552
    lyvinhr00m
    • cụ lý
    p/s: Post bài tiếng việt bạn nhé!
