Phần mềm Revo Uninstaller Pro 3.0.5 Final Full - Phần mềm gỡ bỏ mạnh nhất
Thảo luận trong 'Công cụ hệ thống' bắt đầu bởi shivashiva, 19 Tháng sáu 2013.
    shivashiva
    Revo Uninstaller
    helps you to uninstall software and remove unwanted programs installed on your computer even if you have problems uninstalling and cannot uninstall them from "
    Windows Add or Remove Programs
    " control panel applet.
    Revo Uninstaller
    is a much faster and more powerful alternative to "
    " applet! It has very powerful features to uninstall and remove programs:
    Features:
    Scanning for leftovers after uninstall - With its advanced and fast algorithm,
    Revo Uninstaller
    analyzes an application's data before uninstall and scans after you uninstall a program. After the program's regular uninstaller runs, you can remove additional unnecessary files, folders and registry keys that are usually left over on your computer.
    Forced Uninstall
    - Uninstall even already uninstalled programs. This feature allows you to remove leftovers of programs that are already uninstalled, incomplete installations and uninstall remnants of programs!
    Real-Time Installation Monitor
    has real-time program installation monitoring. It detects system changes during installation, so you can undone them later.
    Multi-Level Backup System
    creates backups of removed registry keys, values, files and folders. It also creates full registry backup each time you uninstall a program. With its unique "Hunter mode", Revo Uninstaller offers you some simple, easy to use, but effective and powerful methods for uninstalling software. You can use it to manage your installed and/or running software programs.
    Install Notes:
    • Install The App
    • Do Not Launch The App
    • Copy Content from Crack Folder to Install Directory
    • Enjoy This Release!!
    You should use SkyMonk to download better at Letitbit
    Download:
