USB Drive Letter Manager (USBDLM) 4.7.0.94 Beta
Thảo luận trong 'Công cụ hệ thống' bắt đầu bởi vncrack, 2 Tháng bảy 2012.
    vncrack
    USB Drive Letter Manager (USBDLM) 4.7.0.94 Beta | 1.2 MB
    USBDLM is a Windows service that gives control over Window's drive letter assignment for USB drives. Running as service makes it independent of the logged on user's privileges, so there is no need to give the users the privilege to change drive letters.
    USBDLM can for newly attached USB drives:
    check if the letter is used by a network share of the currently logged on user and assign the next letter that is really available
    reserve letters, so they are not used for local drives
    assign a letter from a list of new default letters, also dependent on many different criteria as the active user, drive type, connection (USB, FireWire), USB port, volume label, size and others
    assign letters for a specific USB drive by putting an INI file on the drive
    remove the drive letters of card readers until a card is inserted
    show a balloon tip with the assigned drive letter(s)
    define autorun events depending on many different criteria
    many other things, see help file, available online as HTML version too
    Download Links:
